Simatic
KUMARAN
Guest
K
Hello Can any one tell me in detail the merits and demerits of using Block diagrams over ladder logic. Which when is best suited for automation environment??????/
Simatic STEP7 program representation in LAD or FBD?
It is a matter of personal taste. Both are applicable for representing industrial automation programs.
My personal taste is to prefer LAD over FBD. LAD is slightly easier to overlook in a hurry. I think the reason is that LAD is 100% graphical, whereas you have to interpret the ">=" (for OR) and "&" (for AND) when using FBD so it is not exactly as graphical as LAD.
In most cases (but not all) a LAD program can be viewed as FBD and vice-versa.
Look's like a homework question to me!
I will just add one thing to JesperMP's comments:
The maximum number of elements ( -| |- or -|/|- ) allowed in ladder is 12.
When you use an AND gate in FBD you can have a lot more than 12.
I don't know the exact number but I do know that it is more than is allowed in ladder.
This applies to Step 7, other manufacturers may vary
Paul
The number of elements allowed in a ladder rung is not limited to 12 in most other platforms in case you were wondering. In most cases you are limited only by the amount of processor memory. You wouldn't want to put 300 elements on a rung because it would get rather confusing, but there are times when more than 12 elements in a rung is much nicer than making more variables to keep track of portions of logic. Most of the time you won't find a need to go more than 12...but sometimes its nice.
On to the original question...well most block diagram logic developed these days has the capability to run C/C++, sometimes VB, sometimes executables....it all depends on the software used, and almost all of them give you the option of viewing or writting in ladder format.
You pretty much never see any of these added features in a package that dosn't offer the block FBD formats.
A real big advantage to LAD is that your more likely to have a machine electrican understand the logic. Lots more people read ladder diagrams the logic flow charts.
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
99
Dear sir, I am using SIMATIC 300, CPU 315-2DP , (6ES7 315-2AF03-0AB0) VIPA 603-1CC21 A1.0 RAM 32KB, Firmware=V4.0.8 The problem Im using MPI...
177
Hi, I received this SIMATIC S7-300 training kit for maintenance. When I power it up, the PLC doesn't go to RUN mode and the STOP mode led is...
313
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
327
I am utilizing both HMI and SCADA for my project. Both HMI and SCADA have identical tags. When I modify the tag value on HMI, it is reflected in...
166
