SIMOTION VS Rockwell?
Are these just point to point moves or do you need camming, virtual master etc?
Because Siemens sinamics drives without Simotion support ethernet ip
Ie... cu320-2 and s120
the best solution would be to use the onboard dual Ethernet port for software and any HMI/SCADA system access and add a Motion dedicated 1768-ENBT EtherNet/IP bridge which's only duty would be controlling the Kinetix subnet.
Maybe a third channel for EIP devices? I have not used that module before. I know there is a limit to the number of connections,but is that per Ethernet module or per system? Does adding additional EIP Bridge modules increase the connections?
All 3
For AB motion logix, can it use camming function with really absolute camming? I found only relative camming from slave relative to current master position. If you need complex cam function and multi master change over, it will be better to make sure AB can do all complete cam motion task.
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
88
Hello everyone! I'm currently working with SIMOTION D410-2 with a CF Card labeled with SIMOTION D410-2 V5.3 SP1 HF9 + SINAMICS V5.2 HF6 From...
520
Hi, I have a program that is mainly coded with Italian comments. I want to find a way to export all the comments and then run them through google...
1,321
Hi, guys, how are you? We want to build the communication between SIMOTION D435-2 and main controller AB 1756-L72S Could you tell us which...
1,754
Hello, I am new to Siemens' Simotion Scout software. I looked for a thread that might include this but...I have a CU320 and an existing project...
2,642
