Simulation Beckhoff Twincat 2
T4HS
Oct 2016
Hasselt
Hello
I would like to simulate a program i wrote in twincat 2.
I have a 64bit laptop with windows 10.
I tried to use the Simulation Mode in twincat but this does not work.
If I force my contact to 1, my output is not set to 1.
Any ideas on how I can simulate without connecting to a plc ?
Maybe a short written tutorial ?
Regards
Timothy
go to resources,then to the i/o list you made
here you click on your input. that is the only place to put inputs in a state you want, same for analog inputs.
when doing it somewhere in software it is NOT in the whole program.
I have no clue where that is.
In college we learned you can run the program on Local in the laptop.
So you can test everything without connecting to a plc.
I choose in system manager the target local.
But then i cant append my plc program to it ? I dont have the .tpy file if I save it.
So I started looking around and found out that you can put your program in simulation mode also. But when i run my program my inputs are not set high, like in the picture.
in the declaration you can make them true by default, like input : bool :=TRUE;
If you have set all vars you will need to press F7 to put them in the program.
this does work but the output isnt set. Also i would like to run this with visualization instead of forcing my inputs like that
well use start as an input on a visualisation element and use the coil to change the color of another element.
so you need to make a vis with 2 elements.
another one is this POU running ? that is is it in the task list or in MAIN (sometimes called PLC_PRG)
if you need to change from type you will loose the I/O.
sometimes i do it by exporting from a unit and then import only the needed POU etc.
Well I found a way. Installed a virtual machine with windows 7 32bit on my laptop and installed the program there. Now I can run the program without problems. Seems that this doesnt work on the 64bit laptop.
Thanks for your replies !
Only the 32-bit version of windows can simulate.
What I do on a 64-bit OS is this:
Define the program to work with a 'BC-serial' cpu.
Then you can use the simulate option in plc-contro.
One disadvantage: it uses different libraries than a ARM-processor (CX).
But for the simpel things I get along with exporting my simulation and then importing it in an empty program for a ARM-processor (CX).
Good evening ....
I need help, I want to train on Beckhoff but I can not afford to buy it. can I make local execution examples with Twincat 2 with a simulator like nettoplcsim at siemens
It's a soft-plc able the run more than one program on the same cpu. The cycle-time is standard 10 ms but can be made faster.
For me their pluses are:
- many communication modules
- ethercat is 'a piece of cake'
- their support is superb (just one phonecall away - teamviewer)
Downside:
- their manuals
Downside:
- their manuals
Thanks for your prompt response. But, have you ever tried using both Beckhoff and Wago? Which is better?
Has anyone been able to use the Weintek Online simulation tool with the Beckhoff free tag driver? I have no problem running it on the HMI but no...
1,625
90
I am trying to set up a piece of equipment with a Horner HE-X4R. I'd like to use structured text and so far I'm just trying to get a basic On/off...
77
hello every one. i'm new to tiaportal, i have created new project and HMI screen the program works fine with PLC-sim, but when i try to cntrol the...
423
I am looking to upgrade a CompactLogix on V18 to an L83E on V32 which is currently using a Beijer E1151. Does anyone know if the E1151 is directly...
651
