simulation setup using horner OCS using structured text (Cscape)
jdk202
Apr 2024
OK
I am trying to set up a piece of equipment with a Horner HE-X4R. I'd like to use structured text and so far I'm just trying to get a basic On/off switch set up using this. The code is just several lines and assigned the variables to two buttons and the Motor_RUN to an indicator light on the screen.
IF PBMotor_ON = TRUE OR Motor_RUN = TRUE THEN
Motor_RUN := TRUE;
ELSIF PBMotor_ON = FALSE OR PBMotor_OFF = TRUE THEN
Motor_RUN := FALSE;
END_IF;
I'd like to test this without wiring it into the system but the simulation option is grayed out when I go into debug mode. Does anyone know what I need to do in order to do a simulation?
GitHub Link: Open Industry Project This is a side project I've been working on for some time. The goal is to provide an open platform for...
149
113
hello every one. i'm new to tiaportal, i have created new project and HMI screen the program works fine with PLC-sim, but when i try to cntrol the...
520
I am looking to upgrade a CompactLogix on V18 to an L83E on V32 which is currently using a Beijer E1151. Does anyone know if the E1151 is directly...
666
I use the HMI simulation as our production lines are pretty big and we've put an upgrade in over the last couple of months and I've used it most...
763
