siwarex m - how much is 1/4 d ?
girevik
Nov 2005
rus
179
Hello,
i have a question about using siwarex m weight module in Step 7. According to the manual, it seems like I get a true value in bit "status.zero" (in siwarex DB) when the current weight is less than 1/4 d, but how much is 1/4 d - what is this, and is there any way to change this value?
thanks!
still have not figured out the clear answer, so if anyone would explain what does "1/4 d zero" mean, this would be great..
thanks
Just a wild guess....
I don't about "status.zero" but....
I would imagine a 1/4d zero status bit would =1 after a "set to zero" command to the module and stay on until this wasn't true anymore.
Check the state of this bit against the state of the ->0<- LED on the front of the module
thanks for your reply, krk...
it looks like you are right, this bit is activated after the "set to zero" command.
so thanks again..
i just was mistakely thinking that it probably stay true everytime the current weight is less than certain value i.e. current weight is near zero (without set to zero command).
thanks
Hello, I have a problem calibrating siwarex ms with siwatool ms Whatever I have tried, I have communication error and numerous retries to...
76
Hi We have a SIWAREX 231 weighing card controlled via PLC (not stand alone) We have used these for a while with no issues. We can auto and...
1,104
Hello, Can i use this https://mall.industry.siemens.com/mall/tr/tr/Catalog/Product/7MH4960-6AA01 with something like this...
975
Hello all, I need to know more about this module (siwarex wp231) please How to program and how can i deal with it inside TIA portal (address...
1,461
I have looked and looked (obviously in the wrong places 🙃) Im after some examples of both loss in weight and gravimetric feeders (platform...
4,009
