SLC 150 PCIS Question
Grover
Oct 2002
Bay Area, California
22
Greetings.
I am updating a SLC-150 program at our plant and I will utilize the few spare I/O pins and internal bits that are left. To accomplish this I am using the DOS-based PCIS program to change the code and I have encountered one problem- how do I add instruction comments? When I am in edit mode, I have access to the Edit Attributes (F9) function, but it only allows me to type and store data to the right side of the displayed colon, and the text doesn't show up on the rungs. When I invoke the F9 funtion on existing instructions with comments, the commented text will appear to the left of the colon. I don't think F9 is the right function, but nothing else in PCIS gets me as close to it.
Any ideas?
Grover
SLC 150 PCIS Software
Dear Grover,
To add a symbol to the address in the SLC100 software you cursor to the element in question, then after writing down or remembering what the address is, you replace the instruction with the same thing (F1=-] [-,F2=-]/[-,F5=-( )-), key in the address, example: 001, the next key you press should be the first character of the symbol(remember, it's limited to 2 lines of 5 characters each) example:LIMIT. DO NOT PRESS THE ENTER KEY (Charage Return)after entering the address!
The software only lets you do this if your replacing an instruction during the program/ developement mode(offline)
Give it a try and good luck. I would have replied sooner but I just found this web site.
We have an old machine that has a SLC 150 in it and it went down with a fault today of no program. We have the pcis software on an old windows 95...
2,746
I read that DOSBox can be used with PCIS software for Allen-Bradley SLC 150. Does anybody know where I can get a copy of PCIS software? I have a...
42
17,633
So being tired of turning on the old win98 laptop and running it to run PCIS software, I was able to get it to run on XP and communicate using...
38,562
Does anyone know if it is possible to force I/O's on an SLC 150 using the PCIS software without the handheld programmer? I have just begun on PLC...
2,825
Does anyone know where I can download or get my hands on a copy of pcis.exe I have a dead 150 and do not have a copy of the program??????????
8,733
