slc 1747-l40a battery
The battery is a 3V lithium unit, the old one I found is a Sanyo CR14250SE.
Did the fixed I/O SLC's use a spring holder or a wire and plug like the current SLC's do ?
The A-B price is $71 from my dealer.. pretty steep unless you have to mess around a long time finding and soldering on a plug (I'm not eager to heat up lithium cells with my iron).
A quick Google search didn't turn up any easy online vendors, so good luck down at Battery World. If you turn up a good cross-reference to Panasonic or another vendor let us know.
I havent changed the SLC batteries, my L30D also has the Sanyo CR14250SE in it. I have changed ABB batteries to a common camera battery. I match the voltage and ma rating, I couldnt find a ma rating on the CR1425 though. I have soldered many wires to the ends of batteries, naturally I use a very small solder and low heat iron, 15w like this:
15 Watt with grounded tip
I wouldnt be scared to try this battery:
CR14250SESP 3V/850mAh/Lithium Battery with Axial Leads
lithium battery trivia
Sorry, this isn't an answer to your question - but it might make for interesting reading - plus for those of you who work for companies with serious safety programs, this might be a satisfactory answer to the dreaded question: "Where's the MSDS sheet for these things?"
AB Battery Data Sheet
Hello, I've got a project where I need to get information from two ABB ACS880 VFDs onto the plant operator's screen (or alternatively, onto...
23
2,632
I have the following Items connected for DH-485 per the drawing. SLC 5/03 HMI: Automation Direct EA9-T10CL+13Y19B054 1747-AIC #1: connected...
3,057
Hello, First I looked at Manuel and Plctalk but I did not find or maybe not understand. How I can connect ''HTL / Push pull-24 volt encoder'' to...
2,530
Hello I will make it short and sweet. I need the cable that goes from the slc 501 to the 1747-UIC RJ-45 connection. From what I can find it...
1,258
All, Thanks for any help. I am currently changing out an 1747-L543 processor over to an 1747-AENTR card so that I can now run this rack from an...
2,128
