slc 500/03- step7
barridas
Mar 2014
Greece
Hello. I am trying to built a scada station. I have a plc AB slc500/03 and wincc flexible 2008. Does anybody know if i can i use simatic step7 to program the plc, so then to integrade the step7 with wincc? Is step7 compatible with AB plcs?
Step 7 cannot be used the program AB PLC's You will need RS Logix 500 from AB for the SLC. As for as connecting the SCADA to the SLC, WinCC has a driver for AB
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
1,028
Everyone, i am in the process of purchasing the Slc 500 version of software to support what we have and i have a question. Several of our...
800
In a slc 500 plc I am trying to move data with out using a lot of moves. I want to move data from n7:1 to n7:2 and data that was in n7:2 to n7:3...
1,397
Customer has a circa 2004 SLC-500 PLC. Fieldbus is a 1747-SDN DeviceNet scanner. Customer has SLC-500 file (.rss) with no comments. Has no *.dnt...
572
After I tried wiring, I used computer program communication to read the PLC N value, but received a NAK signal. And the DL3500 CHA light keeps...
445
