SLC 500 5/04 and 1761-NET-ENI...
soundview00
May 2012
VA
Hi all. I am in the process of putting a plc training station together in my house, and wanted to connect my SLC 500 to a ethernet network. That said, I was looking into getting a 1761-NET-ENI module. From from what I've read/seen, I could connect my 500 to the ENI card via RS-232 for ethernet communications. Has anyone done this configuration before I actually buy this ENI module off of ebay. Thanks.
Page 1-7
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1761-um006_-en-p.pdf
Device Compatibility The ENI/ENIW are compatible with the following devices and
applications:
All MicroLogix, SLC, PLC-5, CompactLogix, FlexLogix, and
ControlLogix controllers, which support DF1 Full-Duplex on an
available RS-232 port
• Personal Computers using the RSLinx (V2.30.00 and higher) DF1
Full-Duplex Driver
• Other DF1 Full-Duplex compliant products that have at least one
RS-232 port, for example, operator interface devices
• RSLinx (V2.31.00 and higher) Ethernet Driver
I have not done it but I have sold some to customers that have...
I've done this with a 5/03 and micrologix 1200 and 1500's. Should work fine with with a 5/04. It's a pretty straight forward setup with the NET-ENI.
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
1,010
Everyone, i am in the process of purchasing the Slc 500 version of software to support what we have and i have a question. Several of our...
788
In a slc 500 plc I am trying to move data with out using a lot of moves. I want to move data from n7:1 to n7:2 and data that was in n7:2 to n7:3...
1,381
Customer has a circa 2004 SLC-500 PLC. Fieldbus is a 1747-SDN DeviceNet scanner. Customer has SLC-500 file (.rss) with no comments. Has no *.dnt...
569
After I tried wiring, I used computer program communication to read the PLC N value, but received a NAK signal. And the DL3500 CHA light keeps...
437
