slc 500 counters
plcnewbie
Jan 2005
Missouri
220
I do not use the 500 very often to program just troubleshoot existing programs.
I am trying now to add a counter but all the counters seem to be used? Is there a limit? What can I do to get around this if anything? I am sure I am using the C5 file.
Open the Counter data file and click Properties, then increase the size of the Counter file. As eld101 said, you have to be offline to make the change.
-John
Thanks alot that will work. I didnt reallize I had to increae the size. I am used to 5000 where I just name stuff and it happens.:)
So then I guess to change it online then I will have to stop the machine that is running it to update the PLC?
BTW, don't just add one more counter. Add a bunch more. And while you are at it, check the other data files and increase as needed as well. You can click the usage button in each data file viewer to get an idea of how many addresses are available. That way you won't face the same problem again in the future. Unless you are running out of PLC memory there is no good reason to not leave lots of room in your data files.
Please help! I have been working on this for so long that I am probably overthinking this setup and am missing something very basic. I am trying...
2,234
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
1,021
Everyone, i am in the process of purchasing the Slc 500 version of software to support what we have and i have a question. Several of our...
793
In a slc 500 plc I am trying to move data with out using a lot of moves. I want to move data from n7:1 to n7:2 and data that was in n7:2 to n7:3...
1,388
Customer has a circa 2004 SLC-500 PLC. Fieldbus is a 1747-SDN DeviceNet scanner. Customer has SLC-500 file (.rss) with no comments. Has no *.dnt...
571
