jake75 Member J Join Date Aug 2011 Location Cincinnati Posts 4 Aug 30, 2011 #1 Is possible to have two processors SLC 5/03 and SLC 5/04 on the same rack?
Christoff84 Lifetime Supporting Member + Moderator C Join Date Jun 2006 Location Cambridge, ON Posts 407 Aug 30, 2011 #2 As far as I know the SLC racks only accept processors in slot 0, so it would not be possible to do this.
fuzzy logic Member Join Date Sep 2008 Location italy Posts 294 Aug 30, 2011 #3 Nope... SLC-500 isn't a multi-processor system - fuzzy logic
OkiePC Lifetime Supporting Member Join Date Mar 2005 Location ENE of Nowhere Oklahoma Posts 11,794 Aug 30, 2011 #4 No. There are specialty modules which can handle some tasks offloading demand on the single SLC CPU which must go in the first slot which has unique processor only connections.
jake75 Member OP J Join Date Aug 2011 Location Cincinnati Posts 4 Aug 30, 2011 #5 Thank you for the input. I thought so but was not sure Jake75
TConnolly Lifetime Supporting Member Join Date Apr 2005 Location Salt Lake City Posts 6,152 Aug 30, 2011 #6 If you think in absolutely necessary to have more than one processor per rack then consider stepping up to the ControlLogix platform.
OZEE Member O Join Date Mar 2006 Location Kansas Posts 1,695 Aug 30, 2011 #7 I think perhaps a better question to ask so we can help you evaluate is "Why do you want multiple processors?" Based on that information, we might be able to direct toward a reasonable solution that IS possible.
