SLC 500 Pressure test
I changed the graph colors to make it easier to see.
https://youtu.be/cER96UcZQGw
https://youtu.be/So6EQpi3x5o
Ok so the bottom station is the only device used as far as getting a measurement the green represents the on time to look at the pressure in run speed- the white is the on time to look at the pressure during jog speed and is ignored once the machine is up to speed which takes about 3-6 seconds.
The top yellow is the pressure reading and the bottom is the encoder time.
The problem is that when sending a seal through the line at fast speed it only fails 80 percent of the time 8 times out of 10 or less - however in jog speed at 20 ppm or less than 100 ppm- it correctly fails the test part 100 percent of the time.
I have a program that I've used 100 times. SQO settings: File N7:0, Mask 0FFFFh, Dest B3:1, Control R6:0, Length 8, Pos 2. Length & Position...
48
980
Everyone, i am in the process of purchasing the Slc 500 version of software to support what we have and i have a question. Several of our...
775
In a slc 500 plc I am trying to move data with out using a lot of moves. I want to move data from n7:1 to n7:2 and data that was in n7:2 to n7:3...
1,370
Customer has a circa 2004 SLC-500 PLC. Fieldbus is a 1747-SDN DeviceNet scanner. Customer has SLC-500 file (.rss) with no comments. Has no *.dnt...
566
After I tried wiring, I used computer program communication to read the PLC N value, but received a NAK signal. And the DL3500 CHA light keeps...
432
