gordon.greer3 Member OP G Join Date Sep 2010 Location idaho Posts 10 Oct 6, 2010 #16 I loaded the new RSLinx version 2.54 and selected the new driver AB_UIC-1 and still get the error message DiagnosticStatus failed: 0x4
gordon.greer3 Member OP G Join Date Sep 2010 Location idaho Posts 10 Oct 6, 2010 #17 What node should the processor be set to?
sthompson Lifetime Supporting Member + Moderator Join Date Jan 2007 Location Vernon, BC Posts 1,852 Oct 6, 2010 #18 gordon.greer3 said: What node should the processor be set to? Click to expand... The Driver usually defaults to Station 00, and the PLC usually defaults to 01. Can you see your SLC PLC in RSLInx in the RSWho for the UIC Driver? Stu.....
klm Member K Join Date Jul 2007 Location San Diego, California Posts 33 Oct 6, 2010 #19 I'm wondering if you should just reset the processor back to "initial factory conditions". Follow the link listed below: http://samplecode.rockwellautomation.com/idc/groups/literature/documents/um/1747-um011_-en-p.pdf Read pages 24 and 25. Remember to disconnect the battery before trying this.
geniusintraining Lifetime Supporting Member + Moderator Join Date Jun 2005 Location SC Posts 8,278 Oct 6, 2010 #20 This may help (or not) This for my aftermarket UIC but it will be the same procedure, the file was to big so I had to split it into 3 pdf's
gordon.greer3 Member OP G Join Date Sep 2010 Location idaho Posts 10 Oct 7, 2010 #21 I can't see the SLC PLC in RSLInx in the RSWho for the UIC Driver? I can only see my 00, Workstation, 1747-UIC
gordon.greer3 Member OP G Join Date Sep 2010 Location idaho Posts 10 Oct 7, 2010 #22 I just reset the processor and the SLC (01,SLC-5/3,DEFAULT) just appeared!! Well, I think that got it, I'm able to communicate and go-online. Thanks for all you help!!!! I was ready to throw this thing in the trash.
