SLC 504 L542b comm 0 program port setup
mordred
Mar 2004
Red Deer
1,892
Trying to lock the comm 0 as a programming port its currently setting it up as an Ascii port. I've already defaulted the processor and am setting it up merely as a training aid. However I would like to lock in the channel 0 as a program port as I do not have the right cable for channel 1
If you have reset it correctly, then CH0 will default to DF1 @ 1200 baud.
You cannot "lock" the CH0 port per se.
PLC5 has the functionality to block access to various settings in a myriad of ways. SLC500 only has the password and the master password.
Yeah thats one of the settings I came across the other was Chan 0 user set at ascii which I set to shutdown. Appears to be working for my needs by the way what is the correct cable # for Channel 1 which uses the d shell(ps2 style) connection? I currently have the 1747-cp3 which I may try to build an adaptor for it
let me guess 1784-KT-Kt2 with a 1784-cp6
or 1784-pcmk with a 1784-PCM5 with a 1784-cp7
I hope I'm reading this DH+ communication manual correctly there isd a few other options but am I correct in my thinking?
See Pic
Now there is a handy chart thanks Mickey and Ken. Guess I'll continue to work through the channel 0. And if they ever require this processor for an ascii device then I'll have to convince them to get me the other options
Has anyone ever seen this before. I have a SLC 504 running a very small program and it would seem the TON wouldn't start counting using the...
24
4,736
Probably a silly question and asked a hundred times already, but i tried to do some searching here and couldn't find this question. I have 502's...
3,027
I have a SLC504 in the field that is communicating DH+ to several other SLC504 and the RS232 port is communicating to a panel view plus 1000. I...
1,286
As part of an upgrade I am working with 7 different SLC programs. I had the first program in a test controller in my office running and...
2,529
Hi, I am having an issue on one of my station. It won't communicate after the power shutdown. If we cycle the power it is communicating , but I...
1,470
