SLC String + Integer
MicB
Aug 2005
Taupo
Hi
I want to add an integer to the end of seveval strings
I have left the lenght out for clarity
This prints out
ST14:10 Volume =
How do I add the integer to it
I have tried this
But it does not work
ST14:10 Volume = [n15:6]
I want to type texted to the string and then add a variable to the end so different measages can be typed and variables with out have to modify the code just the string file.
I have several lines that will be written and then sent to a display
I have it cycling through the messages and the checksums all work well
goto ab.com. click on knowlege base and search for tech note A18824
this might be what you are looking for.
AJ
I have a SLC 5/05 processor with a Major Fault 1F39h. The processor is running fine with the fault, but I would like to know what is causing it? I...
3,805
Anyone know how to receive the string (UPC Code) from a dataman 302 (Cognex) to a SLC 5/05. I need to be able to retrieve this code, and I am...
1,883
Hi, I have countless times tried to read a tag inside my SLC-5/05 with my panelview plus 1000. I am trying to simply display the name of a...
5,499
Hi everyones, I creat a tag String (example ST10:1) in PLC 5/03 OS 302, and a device tag string in Rsview32,. I use String Display in Rsview32 to...
3,138
Hi all, I am reading in serial data from a Cognex Dataman 2D matrix reader into a SLC 5/04 serial port (channel 0 - user). I have successfully...
3,852
