slc100 and password problems
sparx
Jul 2006
sask
got a slc100 and am using pcis to program. there is a program on slc100 and it requires me to enter a password to clear it with the pcis software. the manuals state to use handheld programmer enter 940 to clear, but the software wont take/use the same method. anyone know how to clear the program (memory) from the slc100 either by software or other. I tried pulling the battery and letting sit for week but program still active (of corse-but if I wanted it to stay it wouldn't have). any help would be appreciated. I already pilled it appart and tried shorting anything I could find. HELP. sparx:
Edit:
I looked in the PCIS software manual and this is what I found:
When the SLC is password proteced, you will be prompted for a password when you:
1. Read the ladder diagram from the SLC to the work area.
2. Clear the ladder diagram from the SLC
3...
There are 996 possibilities, 001 to 999 excluding 356, 712, and 940. Unfortunately the password is stored in the SLC and not in the program file.
HI! this is from sparx. quick reply. I got a handheld programmer and cleared the memmory that way. I don't know if I could enter 900 passwords. Thanks to everyone that replyed! Cheers ;)
Could you post the PCIS instructions on how to enter the 940-CLEAR, the link you posted requires a contract & I'm an independent contractor that can't afford such luxuries. And I don't want to clear the processor memory, then I would have to completely reprogram the customers machine.
Here is a link to the manual.
http://www.plctrainer.net/PCISManual.pdf
See page 6-2 of the manual that is in the link Mickey posted.
The same info is on page 4-7 in the manual in the link below. It tells you how when using a pocket (hand held) programmer.
http://literature.rockwellautomation.com/idc/groups/literature/documents/um/1745-um001_-en-p.pdf
I am looking for some old software or a programming module to connect to a SLC100/1500 (to upload/download program). Rockwell doesn't sell it...
1,683
Any one know what software would be needed to connect to SLC 100 and what OS i will need?
2,090
We have SLC Logistics Revision 2.09. Running Windows 7. We have a USB printer that I have successfully mapped to LPT1: We are able to print...
3,982
Can this adapter be used if computer has no serial port,if so what is used in dosbox config file.
4,750
I'm using this with an expansion chassis to control my home brewery. I can't find any reference in the AB manuals to a real time clock. I would...
3,228
