I'm having troubles connecting to a honeywell xenon 1902 bar code scanner to my slc5/03 plc. I'm using an rs232 cable going to the channel 0 port and then channel 1 right now is just used to connect to the PC. I've matched up the baud rate, data bits and handshaking so that both the scanner and plc are identical but I still can't seem to establish a connection.
The purpose of the bar code scanner is once the scanner has read a bardcode, it will send data to the plc.
Now I am fairly new to doing communication/networking so maybe there is something I'm missing. If I do establish a connection where do the data bits get stored to and how can I tell if I do have a connection established?
As you can tell I'm fairly new to this
