SLC505, Emulate 500, RSView Studio, etc
oldgearhead
Apr 2004
Indy
I just completed a 256 (direct) tag project, using RSView ME, RSLogix500, and Emulate500. Everything went very well, until I to put it on the 'real' hardware.
After removing the OPC server (used for emulation only), I discovered symtax errors in all of my tags {:cornt:[cornt]}b3:8/1
for example (should have been {::[cornt]}. I think this may have been caused by using the same name for both my Linx shortcut and the OPC server. Does anyone know where I can find detailed step-by-step information on setting up the OPC server required for the RSView, RSLogix500, and Emulate500 trio. I don't want to make this mistake again, and I don't really know what I did wrong....
btw- The direct tag access using a PanelView Plus is very fast.
Hello. I'm using bootp to set an ip address for a 1747L551 processor. The bootp program immediately sees the mac id and I am able to enter an...
1,205
I am looking at an old program and doing a retrofit on a sorter. Looking at the ethernet interface, see attached pic, I see a path that is =...
1,497
hi, is there anyone that already know how to using remoteio. i find a point io 1734 POINT I/O but that is for the controllogix. i looking for...
1,365
Setting up a Sick Barcode reader to communicate with the serial port of the SLC. Getting the barcode in the following format when I scan...
1,514
SLC 505s. iFix 5.1 I need a system so that a coop student canwork on their computer to build a new iFix application, modify screens, and edit...
1,725
