Slick automation Direct PLC
dwains
Mar 2009
CA
I hope this isnt on already here but I need simple ladder one line with normally open(part present) one closed(while counter not at 250) it energizes an out put coil while the part is present. This part I got what i really need to know is how to reset the counter to 0 when a reset button is pressed also while the counter is at 250 a bluelight will be lite(outPut) I cant seem to figure out the counter itself in general as stated above it is a slick plc from automation direct. Please help. Thanks Dwain
Automation Direct Slick Counter
I kinda figured out out to connect to the counter but I get the following errors
Main Program : Rung 2 : error C0202: Row 3, Column A : Missing line connection.
Main Program : Rung 2 : error C0202: Row 3, Column AF : Missing line connection.
Main Program : Rung 2 : error C0003: There is no Coil instruction in the rung.
Do you mean a 'Click' PLC?
It might help if you posted what you have so far.
Based on your description, might the attached picture help?
-Eric
That is exactly how I did it. But i still got the errors? Maybe because I copied and pasted the lines in? I will work on it more this weekend. One last thing I couldn't figure out how th labe the inputs and outputs like you have. Thanks for your help. This is the first time I have used Click software. Could you please send me the project file it may help figure out what I am doing wrong. [email protected]
Program is attached. I don't know why you are getting those errors... :unsure:
To edit the address comments, double-click on 'Address Picker' in the tree on the left.
-Eric
Resolved
Dont know why I got the errors your works great thanks very much I will play with it if I come up with an answer I will post it here for someone in the future. Thanks again eric.
Dwain Snickles
One last thought
Eric I have upladed my code at this point. How would I add logic for insurance that a box was removed and replaced before reseting counter or not allowing part pusher to be activated until the box present input changes state again I would have a sensor at input X004 to detect box present?
Great Job
I will thank the teacher:sick: I will try this on monday the scary part about it is it logicaly make sense. Thanks Dwain
-------------------------------------------------------------------------------- Hi I'm working on a personal program for my kids. I bought 8...
2,399
I forgot, what position does the switch have to be in in order to upload and save the program while the machine is running using R/S Logix 500?
1,849
I might have just stumbled on a super slick way to create a toggle in the TWIDO. I downloaded a manual and was looking at the IL instruction...
3,094
Does anyone happen to know how many amps the P2 power supply can output at 24 volts? Thanks
3,980
Hey all in the middle of no where. I have an old computer running win98 with a seriel port. Use this with my pic with no problems at all on my...
3,495
