Slightly OT: Drum Switch Lubricant
elevmike said:
Paula, are you using synthetic belts or leather? I know where to get them but I think I might want to upgrade for better traction.
On my lathe, the drive between the motor and the large countershaft pulley is a standard V-belt. For the flat belt that drives the spindle, I'm planning to use leather. There are synthetic substitutes available, of various types. Leather works quite well on a small, vintage lathe like this, and it's what was originally used, so that's the way I'm going. The ends of the belt will need to be scarf-jointed and glued.
If you do wind up with leather, remember that the smooth side goes against the pulley.
Paula
Hey I've got one of those lathes too, my belt broke a week ago and it sounds interesting to upgrade my belting,where do you get the synthetic instead of leather belts. I havent had any luck finding a belt, thanks..
Hotrod,
Almost any industrial bearing or mechanical drive supplier carries belting. You might also get it from South Bend. Theres a South Bend website somwhere...
Mike is correct, almost any power transmission house can make up a belt to the length you need. Here's one I've heard good things about:
Baltimore Belting Co.
McMaster-Carr also sells various types of flat belt stock.
You can get a "Texalon" belt from South Bend (now owned by LeBlond), but for mucho $$$. Their number is (888) 532-5663
Regards,
Paula
Just curious, does anybody know of a brand of reversing drum switches that are rated for 10Hp and up @480v. We have a few applications where we...
2,146
Hello all. I recently had to re install my AutoCAD Electrical 2024. I am trying to find the Rockwell catalog to install in it but cant find...
114
I have been tinkering with a little DIY remote access stuff lately, prompted by some recommendations and challenges on this forum. To my...
1,866
I need a little sanity check and hopefully advice from some experienced users. I have a mechanism that we're driving with a JVL MAC3000...
1,156
Looking for an economic way to monitor kWh and kVARh on multiple circuits (up to 10) in a single distribution board. The Square D Power Logic...
1,727
