SNTP with ENBT
nemrac
Sep 2022
Columbus
Hello, I am trying to connect to SNTP server to sync the time and date from a 1756-L71 controller with a ENBT/A Rev: 5. The only option i can find in the Rockwell Automation website was and Add-on using sockets, and doesn't work with the ENBT, can someone tell me if there is a way to sync with the SNTP server with the ENBT card. Thanks
Unfortunately, there isn't a way around that using solely the 1756-ENBT. To implement SNTP directly on Logix hardware, you need a controller or Ethernet modules that supports raw sockets, and that begins with the -EWEB and -EN2T, excluding the 1756-ENET and -ENBT.
The conventional way to keep a Logix system synchronized to wall-clock precision was the classic Clock Update Tool, which has been deprecated but is still available. That wrote the clock objects in the controller based on the system clock of a Windows workstation or server on the network.
There are other methods like SyncLink and IEEE 1588 precision time masters and the 1756 TIME GPS module, but all of those are a little more exotic.
Hello everyone, I'm doing a Building Automation with PLC Beckhoff BC9000. Being the PLC free of hardware real-time clock, after the boot of...
1,868
A quick google search shows some information about synchronizing the time between some PLC5 processors, but has anyone done any research on SNTP...
3,451
Hi, I'm trying to use the IO Device Library (Product Versions) which is configured to work with the 1756-EN4TR & 1756-EN2TR but my system uses...
60
Hi All, Has any of you tried to change the IP Gateway of the PLC (of course, essentially of the ENBT card), while in a redundant configuration...
127
please using the usb can i assign any ip address that i want ?
151
