So let me ask this question about HMI progrming
A bit is a memory address that contains either a '0' ("False") or a '1' ("True").
When changing the value in a bit, the bit is "set" (given a value of 1) or "reset" (given a value of 0).
Thus a "set bit" is a bit that has a value of 1.
A "word" is an integer (number), typically consisting of 16 consecutive bits. Typically we think of that word as having a value -- say '5' -- but we can also look at that value as a binary value -- '000101'. Thus, in this word that has a value of 5, the first (usually called the 'zero' bit) and the third (the 'two' bit) are set. This can be a useful technique for packing information, with the HMI reading a single register, but getting lots of information about it.
What the meaning of each bit-in-the-word (or "word bit" as you're trying to use it, although I've never heard that phrase before) is up to you and the PLC programmer(s).
Sometimes it works out that way. Sometimes things are well enough planned out ahead of time so that both teams know what "rules" are going to used to define addresses. Thus the HMI team can link to registers that the PLC team hasn't created yet, but when they do, the links will work.
Time is money, and the bosses can't have someone sitting around waiting for someone else to be done before they can get started. A little bit of planning, a bit of asking "If I can't do X, then what CAN I do?" can speed things up greatly.
Good luck.
Well thanks for the info and in the Weintek software it has Set word and word lamp my mistake on the bit word.
In EB8000 a set word has 2 modes of operation, Manual/Automatic Manual mode can change the value in a designated word address when the object is touched. In automatic mode the word register is automatically activated when a predefined condition occurs, touching the button will not affect
A word lamp is simply an indicator which displays the states according to the value of a designated word register.When the value of register is 0 state 0 displays, value1 displays state 1 and so on
So you can't us a lamp as a push button. Well what one can you use to change colors when it is full and another color when it is empty and can be used as a button at the same time.
Use a Toggle Switch. It's a bit lamp with a switch function.
Use buttons with at least 2 states from the Picture library.
On your switches, use Momentary only. Do not use set bit, reset bit, and toggle.
This simplifies the actions of the HMI, and forces all of the latching/unlatching in the PLC.
Someone please post a ladder in Mitsubishi showing a NO start button and NC stop button as an example using momentary buttons.
Hello everyone! So basically I have this PF 525 that no matter what I do won’t let me speed down. It always shows 66.66 Hz and the parameters to...
1,192
35 years ago - 167 Souls were lost on Pipe Alpha (Oil Platform in the North Sea) all due to a failed management system See more information here...
806
I have begun using 480VAC power supplies in my panels to keep heat from a transformer out of the panel. This works great if the panel is mounted...
17
4,144
I am deciding on components for a bayed modular enclosure containing multiple VFDs (480V/350A/321Hp each) for a dynamometer. I am concerned given...
1,716
Hi, I am having trouble with the comms within FT view SE v11 (premanent license). I created an HMI program a while back which was working just...
927
