Somewhat O.T. - a real-time timer
Von
Jul 2006
Florida
50
Hey all,
I need to exercise a generator for 4 hours on the same date each month (all 4 hours at once).
I'm looking for some type of "off-the-shelf" real-time timer to do this.
Does anybody have any suggestions?...
My web search thus far has been disappointing.
TIA, VoN
Some of the low end PLCs have built in clock/calendars. The 28 point GE Fanuc VersaMax Micro does, although neither the 14 point Micro nor the Nano do. The Automation Direct DL06 has it. The DL05 needs a $49 add-on cartridge. I'm sure there are others.
A time clock would be able to do this. A Schneider type 16335 is a 365 dat time clock with 6 year battery back up for example.
The last time I used a generator on a project, the customer wisely spec'ed it with it's own internal timing module specifically for the purpose you want. Exercising a generator is normal considering that you don't want it to fail when you really need it.
Does your model have such an option?
Thanks to all for your ideas...
I did look into a few of them such as the programmable relays but worried about reliability and ease of reprogramming by others (after me); then the sprinkler type, but I did not find any that were "365 day" capable, most were 7 or 14 day. I went with an Intermatic 70115 series next gen. type. A bit pricey at about $250 USD but very flexible and a very trusted brand.
VoN.
For a 365 day unit you can not go wrong using Intermatic, they have been around more or less all my life and I sm over 50, definitely tested and proven.
Plus, you wouldn't want your generator to get fat.
This is a bit off-topic in a strict PLC sense, but it is in the process measurement area. I need to strip some Alpha 9058C coax to mate with TE...
21
4,830
Just throwing this out there since there may be some who aren't aware of the differences between Pozidriv and Phillips screwdrivers - or even the...
4,281
Hi group, I need a single phase 120vac speed control for a 1/2 hp gear motor, that is running a hoist on a degreaser system we are building. I...
1,828
Hi all, just wondering if there is a list of resources and locations somewhere on this site? Would this be a good thing? I happen to be in need...
1,609
I have been involved in panel design and building for nearly 18 years and have used various methods for supporting and/or rigging the panels while...
30,833
