Another question. Do you generally mount your solenoids on the outside or inside of the control panel? From an electrical standpoint I would prefer to mount them on the inside. But then you have to deal with getting the air lines to the solenoids inside. I have used bulkhead type fittings for this but I don't really care for them either. In my application I have to be concerned about water (we build water purification systems) so any electrical components on the outside have to be protected. So if mounting the solenoids on the inside of the panel what method do you use to get your tubing to the solenoids? We would typically use 1/8" tubing.
And, yes I do understand what you mean about being able to easily remove the solenoid from the manifold.
