sourcing and sinking concepts in S7-300 CPU.
n.navaneethan
May 2009
20
SIEMENS CPU 313C-2DP
6ES73136CF030AB0
16D.I/16D.O,3X30Khz HSC
32 KB RAM, 24V DC SUPPLY VOLTAGE.
I'm going to use the above CPU in a system, Please guide me weather this CPU provides sourcing or sinking I/O's or both.
Sorry, I checked up with the manual, but I can't get the required information.
Can you tell me how to connect a NPN and PNP type sensor in the above mentioned CPU I/O's
Got it..
Thanks ivo.maenen, i got the answer this time, as you said only PNP type sensors can be used in the above mentioned CPU, not NPN.
Good morning all. I have never seen this done but I want to ask if it is possible. On an AB 1766-L32BWA, can you have some of the inputs wired as...
2,381
I have a client who has installed a control system which was designed offshore (ASIA), and uses a power system common to the Asian market. The DC...
1,939
Hi there, I have a 2 wire npn sensor. For example in this diagram: I'm guessing i should connect it to a PLC dc sourcing input as such? Would...
5,273
Hello again guys, I've read tons of informations on sinking and sourcing inputs and outputs, however there is something bugging me with this. I...
4,393
We are some students thinking of buying a logo!8 starterkit to connect diffuse photosensores to the digital input. some of the sensores already in...
3,312
