More information
Sorry it took me so long to get back. Thanks a lot for the input. Here is some more information about this application. This is a food production plant. We run 2 production lines with 4 variable speed belts on each line. Hydraulic pressure is maintained with 4 central low pressure pumps. Speed is currently controled with a manual flow control valve. The sole purpose for not using and encoder and a VFD is the additional cost of the encoder, processors, and the hassle of running I/O wiring. Dwell time is defined as the amount of time that the product spends on the belt. The range of these dwell times are between 30 seconds and 700 seconds. The timer in my program times 4 pulses - a pulse is defined as a full prox cycle, high to low and back to high. The main problem that I am having is at the low end of the range at dwell times of greater than 400 to 500 seconds. It is taking to long for for the speeds to update. I had thought about using more teeth but when I do this I have troubles with my accuracy at high speeds, 30-60 second dwell times. Thank You everybody for your input.
