Step 5 comunication cable
Nit
Aug 2008
Bacau
Hi
I have a Hyundai lathe with Step 5 PLC. When I try to comunicate with the PLC I receive a message "Last segment not completed" I use a laptop with an original cable. It's neccesary a converter?
Best
Nit
Which laptop you are using Siemens or other than siemens?
What do you mean by original cable?
Siemens supply covertor cable compatible to RS232 communication.
If you are using original convertor cable then it should work.
Normal cable without convertor will not work with your laptop.
Hi
I use a original cable suplied by Siemens and he doesn't have any converter. I use a Compaq nc6120 laptop. What you undersand by convertor? It's a device or only the corespondent configuration from RS232 to PLC?
Siemens S5 PLCs commumicate by a rs422 current loop protocol. The origianl siemens programing terminals had the current loop converter built in and used a cable with a 25 pin connector on one end and a 15 pin connector on the other end. The exception to this was the S5-150 series which did use a 25 pin to 25 pin type cable (stretching my memory a bit here).
To run STEP5 on an ordinary laptop you need: 1. A real serial port with a 16450/16550 UART chip (not a USB one). 2. STEP5 Software 3. PC to current loop convertor part number 6ES5 734-1BD20.
Hope this helps.
Nick
Nick
not quite right, look at here
http://**********/viewtopic.php?t=8348
Compaq nc6210 has onboard COM port, but I don't know "real" or not. Sometimes COM port in notebook it is just embended USB-COM converter. :)
Thanks for the Info. that does look like an interesting product but it doesn't seem to be running Siemens Step5 software. As I understand it, The Siemens software requires a real UART to go online.
Have a good weekend,
Nick
DO you have any part no. for cable?
Siemens also make cable that can be used for any RS232 port.
And the convertor circuit is fixed inside connector and this works on 5 v power from com port.
And it should works with compaq nc6120
Try switching to STL reresentation. Usually that meesage appears as a result of a program error, not a comms error.
You will probably find that the last segment dosn't have a valid output, but it should still display in STL.
Hi
Thanks for replay. Yes I have a code nomber : 6FC93-44RY-001AF0. Do you have another code nomber? If yes please send it to me.
Nit
Hi
I can be agree with you but why when I try to transfer from PLC to laptop I receive same message?
Nit
I am having a step7 v5.4 program where the blocks are encrypted and locked. And the manufacturer is stopped the support. Is there any ways to...
182
Good Morning, Hoping someone with some Siemens experience can give me a hand with this one. Customer has a S7-200 cpu, which has a 6GK7...
253
HI! HOW COULD I OBTAIN THE NAMES OF THE STEPS OF A ROUTINE IN SFC LANGUAGE IN STUDIO5000? Or is there a system variable that gives me those...
343
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
557
Hi Siemens Experts, I am hoping someone can shed some light on my issue. I have uploaded the code from a S7-300 (317-2PN/DP) using Step 7...
690
