Step 5 TNB instruction with operand of zero!
WA_Sun
Sep 2015
Westerm Australia
Slogging my way through re-writing a Step 5 program in RS Logix, I have come across this segment:
A F 60.7
A T 28
A I 3.4
A I 3.5
AN I 11.2
A I 11.7
= F 70.6
TNB 0
A(
A I 30.6
A I 17.1
O
A I 30.7
A I 17.0
A I 37.7
AN I 38.0
L DW 28
SD T 28
NOP 0
NOP 0
NOP 0
NOP 0
All fairly simple except that "TNB 0" statement.
As far as I can tell this is a bytewise transfer of zero bytes, i.e. do nothing.
Am I missing something or is there some "programming trick" being employed? I can't see why this is not two separate segments with the second segment starting where the TNB is.
Any thoughts gratefully appreciated.
Strange.
The 'segment end' instruction could have been manipulated in the CPU to make the segment too long to be viewable by the Step5 software - a primitive kind of knowhow prot.
What does the preceeding code look like?
Kalle
The code either side of that segment is very simple bit manipulation, so simple it will display in ladder as would the above if it was two segments without the TNB 0.
Since then I have come accross another one:
Logically segment 5 should start A Q 24.6 if the code for T 55 follows the code for T56 - they are a left / right pair of devices.
This program is something like 20+ years old and has been modified continuously during that time. Could it simply be a corruption - original software was DOS and floppy based?
I'm using IBH S5/S7 for windows to view the code.
I am having a step7 v5.4 program where the blocks are encrypted and locked. And the manufacturer is stopped the support. Is there any ways to...
205
Good Morning, Hoping someone with some Siemens experience can give me a hand with this one. Customer has a S7-200 cpu, which has a 6GK7...
264
HI! HOW COULD I OBTAIN THE NAMES OF THE STEPS OF A ROUTINE IN SFC LANGUAGE IN STUDIO5000? Or is there a system variable that gives me those...
356
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
565
Hi Siemens Experts, I am hoping someone can shed some light on my issue. I have uploaded the code from a S7-300 (317-2PN/DP) using Step 7...
705
