Step-7 and FB2 P_RCV blcok functionality
Levanteri
Jan 2008
Cluj-Napoca
18
I`m trying to operate my PLC(CPU314) with Hyper Terminal
via CP340. I can send information from the PLC to the Terminal and it works fine.
The problem is that it doesn`t work the other way around as it should; when is send a set of characters, for example the word "perkele" it is received only in the first receiving byte character by character and not as a full word in all of the receiving bytes, why is this happening?
I`ll attach a picture to show what I mean.
http://www.flickr.com/photos/7938592@N05/2232115931/sizes/l/
In the hardwareconfiguration for the cpcard under Parameter-->Protocol you have settings for how you want to end recived message. You probably have On exipiry of character delaytime activated. Change to end character CR (carriage return) that way message will be "received" when you press enter
I am having a step7 v5.4 program where the blocks are encrypted and locked. And the manufacturer is stopped the support. Is there any ways to...
213
Good Morning, Hoping someone with some Siemens experience can give me a hand with this one. Customer has a S7-200 cpu, which has a 6GK7...
266
HI! HOW COULD I OBTAIN THE NAMES OF THE STEPS OF A ROUTINE IN SFC LANGUAGE IN STUDIO5000? Or is there a system variable that gives me those...
359
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
567
Hi Siemens Experts, I am hoping someone can shed some light on my issue. I have uploaded the code from a S7-300 (317-2PN/DP) using Step 7...
714
