step 7 can't interpret as project
JOLTRON
Aug 2006
MI
692
Got another one for you guys.
I have a Step 7 archive that when I try to retrieve it it says that Step 7 cannot interpret file as a project. It then throws it in the s7proj folder in its own folder named TMP0001
I can use the open feature in S7 to goto the file in the TMP0001 folder and open it and it seems fine. But if i archive and retrieve again I get the same message.
I can also use winzip to unzip it then open the file that has been unzipped.
Has anyone seen this before?
I will be calling the siemens tech support first thing on monday.
Thanks,
-Joel
Are you sure it was originally archived from Step7 ?
Do an experiment , once you get it open , re-archive and see if it works
Some people don't use the archive from within Step7 and it screws up the project
Thanks alot. I've only had to use that 1 other time and forgot about it.
Save as with re organize slow worked.
Before that I even tried a re organize then save as and it didn't do the trick. Didn't now there was that much difference between the 2 ways of doing it!
After trying it on another pc the file that I did a save as + reorg slow which worked last night, I found it still had errors when trying to retrieve on another machine.
1 thing I found was some SCL source code in a machine that didn't have SCL installed on it.
Apparently that makes a machine very angry.
Did a save as + reorganze (slow) on that machine and it fixes the problem by deleting the source file.
Crazy stuff!
Crazy stuff!
I should have read your first post "closer" :)
Can you post the project?
Sorry, I must not have been clear. :)
I'm not very good at saying what I'm thinking
But in my last post I was trying to say that the issue is solved, I had to do the Save as with Reorganize (slow) on another machine. One without SCL. And it fixes the issue by deleting the SCL source.
Thanks,
I am having a step7 v5.4 program where the blocks are encrypted and locked. And the manufacturer is stopped the support. Is there any ways to...
214
Good Morning, Hoping someone with some Siemens experience can give me a hand with this one. Customer has a S7-200 cpu, which has a 6GK7...
267
HI! HOW COULD I OBTAIN THE NAMES OF THE STEPS OF A ROUTINE IN SFC LANGUAGE IN STUDIO5000? Or is there a system variable that gives me those...
359
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
569
Hi Siemens Experts, I am hoping someone can shed some light on my issue. I have uploaded the code from a S7-300 (317-2PN/DP) using Step 7...
714
