Step 7 Replace Instruction Type... not delete add new
timryder
Feb 2007
Macomb MI
176
So in nearly all Ladder Logic software, you can replace an instruction type by right-clicking on it and changing it from a NO to a NC or etc. Does anyone know of a way to do that in Step 7? Is it possible?
Just find it tedious to have to add a new instruction copy the address paste it into the new instruction and delete the old one all the time.
Yeah it just creates a new instance of a Contact on the rung. I was hoping for some way of like.... While I have the particular instruction Selected or highlighted, pressing Shift+F2 will replace the already NC with a NO. But no such luck so far.
Thoughts?
Mike_RH You sir get a point today!
That did it, there is a status in the status bar for it as well.
Thanks for that simple tip.
By the way, be careful with this new found power. Make sure you press insert again to switch out of replace mode.
It's really easy to make a few modifications, step away, and lose track of what you HAD been doing. When you go to add new code somewhere else, you end up overwriting what you had.....
I am having a step7 v5.4 program where the blocks are encrypted and locked. And the manufacturer is stopped the support. Is there any ways to...
195
Good Morning, Hoping someone with some Siemens experience can give me a hand with this one. Customer has a S7-200 cpu, which has a 6GK7...
259
HI! HOW COULD I OBTAIN THE NAMES OF THE STEPS OF A ROUTINE IN SFC LANGUAGE IN STUDIO5000? Or is there a system variable that gives me those...
346
I'm just trying to figure out the right method of adding a DO card to an existing rack. It's not the *next* open slot, but I have to move the AO...
560
Hi Siemens Experts, I am hoping someone can shed some light on my issue. I have uploaded the code from a S7-300 (317-2PN/DP) using Step 7...
695
