jwilcoxson
We are working on a project in which a few CP343s will be communicating with several hundred other S7-300 CPUs. It seems like NetPro only lets you configure a certain number of connections per CPU. Would there be a way to dynamically change the target IP address, in order to reuse the connections? The SP343 is the Active partner and we are just using Get/Put. We only need to communicate with the remote CPUs once every few hours or few days, so there isn't a need to be connected to all of them at once.
