Strange Philips PLC
modac
Sep 2004
Minnesota
Greetings everyone,
I've salvaged a Philips PCL from a machine that I scrapped out. I would like the use the PCL for a new project, but so far all my attempts to find hardware/programming manuals have added up to ZERO.
I believe the PLC model is called PCM1000/2, and it uses something called ISCOS 70 for communications on the backplane.
Does anyone have a clue where I can get information on this PLC?
Thanks in advance
Hello all, I am facing an issue with my Commander SK that I cannot solve on my own, I am struggling on it since several days :confused: The...
1,073
Hi. I'm doing an upgrade of an old 1400e to a new panel view plus 7 standard using ftv studio v 12,which will be communicating to a slc 5/04 via...
2,645
Can someone explain the jumper between the elements? Does it do anything? See attached jpeg.
694
We have an OPC server getting data from a Compactlogix PLC. The PLC also communicates with a Panelview and a couple VFDs via Ethernet/IP...
1,172
I have a small system controlled by a Siemens S7-1200 PLC. I created a totalizer function block (TIA v17), where I'm counting total revolutions...
3,161
