Studio V31 - Alarming
These enhancements have been made to the Structured Text editor:
Use outlining to organize a Structured Text routine into collapsible segments. Define segments automatically using automatic outlining, or by marking specific regions.
Use code snippets to insert predefined blocks of code into a Structured Text routine. Type a keyword for a code snippet and then press Tab to insert the snippet.
Toggle the display of inline values.
Select Smart indentation mode to use automatic indentation when adding lines to the routine. Use the completion prompt to see possible completion options when typing in the editor.
Monitor inline values.
Use change bars to indicate updates. Show or hide line numbers.
These enhancements have been made to the Function Block Diagram editor:
The default sheet size has been changed to 11" by 17" (landscape orientation). Change the sheet size while online.
Force I/O tags from the context menu. Modify operand values directly.
Hi everyone: I need to upgrade my Studio 5000 to from V31 to V33, but when I try to download from Rockwell PCDC, I only have the option up to 31...
1,406
I have a v31 project with several 5069 AENTR com modules. When I open this project in certain VM using RS Studio v31, it will not recognize the...
813
Guys, beating my head on a wall here. I have two simple date-times and I want to find the oldest. Are there any better ways to do this beside a...
3,510
  • Poll
Hello Everyone, Is it a good idea to make the switch from 31.011 to 32 or 33? I am currently using 31.011 on all of our 5370 L33 or L36...
7,796
Hi, I recently started using Logix Studio v31 after having been using v20 for years. I keep getting these fatal error seemingly at random a few...
3,934
