Talking to the Logix5000 family of controllers via PC/Ethernet
Epy
Jul 2012
no
376
Hi all,
I found this old thread: http://www.plctalk.net/qanda/archive/index.php/t-19056.html
but was wondering if anything new has turned up in the past 9 years.
Simply put, I'd like to grab information from any of the Logix5000 family via PC over Ethernet using a library of some sort. Programming language or platform doesn't matter so much as cost. We don't have $2000 to spend on a library, we'll go Modbus TCP/IP before that happens.
Anyway, TIA.
Ingear also has (for the fellow or madam who only wishes to do one PC system) a $300 version:
Design, test, debug and run Windows programs, system services, console applications and more on a single machine. Ideal for the developer that needs to leave their customer with a licensed copy with their project source. - See more at: http://www.ingeardrivers.com/netlogix/netlogix.htm#sthash.8ueBAsrp.dpuf
AdvancedHMI includes drivers similar to Ingear at no cost. The AdvancedHMI drivers are designed to be easier to use for the first time developer, but yet still has the features to do advanced tasks.
Hi All, Got a funny issue. I have a 1756-L85EP and a 1756-EN2TR in the same chase. The client asked for the Ferrari and the 3 lane highway!!! We...
189
Hello friends, I am tasked to get a SVX9000 Eaton VFD to talk to a plant which uses Proficy Machine Edition (PAC systems RX3I) PLC. The VFD has...
1,877
What is required for a ControlLogix PLC to read/write tags from a Schneider PACDrive LMC PLC? Does the PACDrive have Ethernet/IP protocol built in...
1,767
Hi Guys Moments ago I just had my first ENBT failure. While the front of it showed everything was fine, it would not respond to ping or to comm...
1,356
I am very new when it comes to programming thing using a Prosoft card using Modbus. I am fine to figure that out by studying the manual. However I...
1,191
