Temperature Reading check
ceilingwalker
Mar 2010
Phoenix, AZ
1,586
Good day all. I'm about to load a program I had to edit and want to see if someone wouldn't mind taking a look to see that I have selected the correct integers to interface with Quick Panel HMI. I want to be sure that my tank temperature and set points i've listed below will be correct to use as the tags for my HMI, to display what it is I need displayed. I have a SLC5/03 and Quick Designer v3.7 software, using RTD's for temp. I thank you for whatever help you can be.
Station 8 Tank Temp N140:43 Set Point N140:3
Station 14 Tank Temp N140:56 Set Point N140:16
Station 15 Tank Temp N140:58 Set Point N140:18
Station 19 Tank Temp N140:62 Set Point N140:22
If N140:3 is the Station 8 Setpoint, I suggest that you label it in the program Database to be "Station 8 Setpoint". Right now it has no label, so I can't verify what it is.
If N140:18 is the Station 15 Setpoint, I suggest that you label it in the program Database to be "Station 15 Setpoint". Right now it has no label, so I can't verify what it is.
If N140:22 is the Station 19 Setpoint, I suggest that you label it in the program Database to be "Station 19 Setpoint". Right now it has no label, so I can't verify what it is.
Hello, I am working on a project where I have to record the temperature reading for 4 ethylene glycol solutions using 4 K-Type Thermocouple...
1,884
Good Morning, We have an application where we want to read the temperature of the a PanelView Plus 1000 HMI, and use this as a basis to determine...
1,206
I am working on a home project that I am logging temperatures indoors and outdoors. I am using type J thermocouple going to a 1746-NT4. I...
5,353
Does anyone know why I’m not getting any temperature reading into my PLC? I’m not getting any RAW data at this Variable V7677. I loaded...
3,596
E
Hello: I am using a GE Fanuc series 9030, I am trying to get it to accurately read temperature. The analog card is set up, and I do get a...
4,865
oldgearhead
O
