Think Pad (IBM)
Dallas,
When you finally get your connection strightened out, you will find that programming with a PC instead of a hand-held like stepping out into the light from groaping around in the darkness.
If you make the cable from parts, take the drawing I posted to Radio Shack. Youll have to buy the cable, the 9 pin connector, and the 6 pin RJ phone jack seperately. You'll also need a RJ crimping tool that will crimp a 6 pin plug. Most are built for 4 pin only so take note of that.
The usb adapter might not be availabe at Radio Shack. If not, If you have a Computer Builders Warehous store near you, go there. They sell everything you'll need.
Have Fun.
The usb adapter will have a USB plug on one end, and a 9 pin serial port on the other end. You will then plug your porgramming cable into the 9 pin connector on the USB adapter, then you will plug the RJ plug on the programming cable into the TOP port of the PLC CPU.
In a previous post I provided a link so that you could purchase both cables from Automation Direct. At this point, it might be easier for you to just call AD and talk to them and get exactly what you need. They are smart people that know what you will need and will be more than willing to sell you the right stuff for no more than you will spend in time money, and effort to buy it at a computer store.
Time is money. Call AD 1-800-633-0405.
Got it
Thanks, sorry for the stupidness....Yes, I know time is money...I need to have this project done. It is a multiple machine sales deal..
I bought the usb to serial adapter cable...now I will purchase the hub for in between. Thanks again.
There's NO HUB INVOLVED! banghead
You will need the following:
1. USB to Cerial Adapter. (I prefer Frosted Flakes) The adapter should come with some configuration software.
2. The AD programing cable. (the one that I posted a picture of before)
My personal opinion: Buy an old laptop with a REAL SERIAL PORT on ebay. My laptop is a 500mhz Winbook with Win 98 SE & 250mb ram. It works fine with all of my PLC programming software. Unless your watching movies, or playing the latest video games you dont need the latest-greatest Laptop.
USB ADAPTER
The light finally came on....I am connecting from the laptop to the usb -adapter and out to the top port of the 250. Man, That was pretty simple...
Why didn't someone say so in the first place.....:)
New IBM Thinkpad T60, 1gig RAM, WinXP Pro. Trying to get a PCMCIA to Serial Converter to work with S5 but so far no luck! Converter is good, tried...
3,152
i tried to download my project to an tp37 in protool6.0,the tp37 already in serial trans mode,but the connection couldn't established. tp37 &...
4,441
Hi folks, We have IBM thinkpad R30 with a USB to RS232 Belkin converter model F5U103. The converter is assign at com3 then I configure the...
3,919
267
Hey all, i have a panelview screen (image attached), with 4 items on it. Program 1, Program 2, ...3, ...4. The PLC i am using is a compactlogix...
279
