Thyrister Based Phase Angle Control In
farooq mohd
Apr 2003
hi,
dear friends,
i have a problem related to thyristor based phase angle control in three mode. for detail please reffer the following attachment .
please suggest any solution or tips.
To firing the R phase you are using the U_RB voltage. This voltage is delayed of 30 degrees with respect to U_R0
To firing the Y phase you must use the U_YR voltage and not U_RY, because U_YR is delayed of 30 degrees with respect to U_Y0
the voltage U_RY is delayed 150 degrees respect U_Y0 so your load is unbalanced
THANKS RGUA FOR YOUR REPLY
hi rgua,
first i want to say thanks to you for your reply.
as per your suggestion we change phase sequence
RY to YR .but my friend untill i didnot get required voltage
that means balanced output,by changing phase seq.as you suggest.
i also want to ask you one question that in your reply
you write U_RB and U_RY what does it mean please explain it.
changing of phase seq. does it matter? please explian it .
i hope that you understand my problem .
farooq.
The sequence of phases R, Y, B is important for the control.
I assume U_RB is the line voltage between R and B.
regards
Hi I have a ifix 5.5 application where the operator opens a valve by clicking on a screen object. I can trace from object to data base that it is...
46
Hi, I wanted to ask is there a way to have a visibility expression use the IP address of the HMI (Dynics, not PV) to show certain elements? The...
222
Hello, I am trying to setup on plc so If I enter 60 jph (job per hour) it will send the vfd hertz based on what jph is entered by...
174
I have an array of 55 REAL values. Is there a way to multiply based on the array location ? I have 55 transfer belts that are equally spaced...
170
Hello everyone, nowadays i am working on a project for remote access to our machines. We are using a remote access module, but i want to make my...
404
