TIA portal - modbus tcp
Varri
Jan 2020
South
30
Hi!
Science we don’t get any ready-to-go modbus functions from my Siemens I wanted to ask you TIA users:
In your experience, what’s the best practice for modbus with Siemens?
Modbus blocks are in the comms section of the instructions. I've just used them to talk to a nidec drive.
Just to add that Siemens is pretty sh***y with Modbus implementation as it doesn't support function 23H ( read and write multiple registers)
Which commercial Modbus Master/clients do support Function Code 23H? I have yet to run into one that does.
There are slave/server devices that support FC 23 and there's one odd-ball that supports only FC 23, which display a remarkable ignorance of market conditions in my opinion.
@danw
Most HMIs and VFDs I use support it. Mitsubishi and Codesys based PLC use it. It makes life much easier for programmer when you can read and write in one cycle.
Hello gentlemen, Im working on a small project on TIA Portal, about establishing a Modbus TCP connection between my ET200SP plc and a socomec...
319
I'm trying to communicate with a heating controller over Modbus RTU (RS485) but I'm running into the common issue of having no Rx light. S7-1200...
4,050
I have a system with an ET200SP controlling a Profinet network already pre-established. Am I correct in that I can add a Modbus TCP/IP node and...
1,912
I am beatin gmy head against the wall trying to get my modbus comms working. I have a s7-1200 running tia v14, a cm-1241 comm card. I have...
22
7,408
I am trying to commission a compressor that is using a s7-1200 to communicate rs485/modbus to a the compressor interface. My rs485 module is a...
1,704
