TIA Portal S7-1200 Creating Profinet Alarms
rorkie
Mar 2014
UK
I would like to create an alarm to the HMI for when the profinet connection has been disconnected from the S7-1200 to the IO.
Could somebody point me towards the right direction on how this could be done using TIA portal V11.
In V12, there is an extended instruction called LED. It may be used to monitor the status of the network link status LED. I am pretty sure it is in V11 as well.
...and I agree. Context: TIA Portal/HMI = KTP1200 (12" screen) In the attached redacted image, the values in the white boxes are entered by the...
714
Good, Code Totalizer: IF ( Hour = 23) and ( Minute = 59) and ( Second = 59) THEN totalizerDay_previous : = totalizerDay; totalizerDay= 0; End_IF...
1,566
I am new to Siemens world and need some help. There is existing program and I need to modify Function Block, add some inputs. I am offline. I...
1,948
Hello all, I am working on a project using an s7-1200 and tia portal v17. The project is for stepper motor control for a SMD23E2 motor. I am...
5,289
Hello all, I'm very new to PLCs, and I'm working on a system utilizing an S7-1200 PLC with a KTP400 Basic HMI, and it was programmed in Tia...
2,032
