TIA Portal V14 Online monitoring problem
Blue Fox
Feb 2013
Basildon
49
Hi All,
I am hoping someone can help me with a problem I have with V14 of TIA Portal that I have just upgraded to.
When I try to monitor a function command in ladder logic the colours all change from the non monitoring version but the states of the bits doesn't change in the ladders, i.e. a bit which is true isnt showing in green like it has on all the previous versions of TIA Portal I have used. I am getting the status of all the function commands and all are showing green i.e. online and offline are the same, system is saying it is online and if I modify a bit from 0 to 1 that is also working but even if I modify it myself the colour of the bit doesn't change. :confused::confused:
Any help very gratefully received!
Hi All,
I often have this happen when I write an FB/FC, but then forget to actually call it from somewhere (OB1).
Thankjs fro the reply, It is just as if the function block isnt being called, however it is as the program is running so I really cant understand why it is doing this?
When you say the program is running, what do you mean by that? Is the PLC executing the specific FB you downloaded, or just some things?
Is there any error message in the lower window?
Thank again for your help. Yes the program is executing the FB im trying to look at, I've now also tried going online with Tia Portal V13 on the same laptop and it is all working perfectly it just the V14 that I'm having the issues with.
Did you select the correct call instanc to monitor? Check for "call environment". If you call an FC 10 times then you can select which call to monitor. I don't have TIA at home so that I can post a screenshot.
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
107
Hi everyone. Please help me to upload program from S7-1200 with TIA v14. I created new project, go to Online tab, select Upload devices as new...
1,089
I am beatin gmy head against the wall trying to get my modbus comms working. I have a s7-1200 running tia v14, a cm-1241 comm card. I have...
22
7,414
I am trying to commission a compressor that is using a s7-1200 to communicate rs485/modbus to a the compressor interface. My rs485 module is a...
1,707
Is it possible to install Siemens Tia Portal V14 on a machine that already has V16 installed? Or do I need to create a virtual machine to install...
17
8,928
