TIA Portal V14 SP1
Elcan
Apr 2008
NC
935
Hi All,
Has anyone experienced problems with the V14 SP1 upgrade?
I used the Updater to go from V14 to V14 SP1, and I ended up not being able to open my existing V14 projects...
Well, its seems either nobody have had problems or nobody has upgraded...
I did a clean install of SP1 just about 3 days ago, no problems so far.
What error are You getting while opening?
It's claiming that Step 7 Basic is missing. However, I have Step 7 Professional.
M Turk
If he didn't upgrade all packages to sp1, he would get the "Side by Side error"
I think he upgraded Basic and not Professionally or vice versa
You can see best what can be upgraded in TIA updater.
Did you upgrade it manually or via Updater?
Are you trying to open a V14 project or a V13sp1? I'm not sure what SP1 opens and what not...
Via Updater.
I installed V14 SP1 and I'm trying to ope a V14 project.
You only have Step7 Basic installed. So you can't open a project with anything but a 1200 CPU. Also Startdrive needs to be updated
Hello, good morning, I have been having two problems with the Tia Portal software. The first is that I have installed it on my computer and...
73
Hi everyone. Please help me to upload program from S7-1200 with TIA v14. I created new project, go to Online tab, select Upload devices as new...
1,087
I am beatin gmy head against the wall trying to get my modbus comms working. I have a s7-1200 running tia v14, a cm-1241 comm card. I have...
22
7,408
I am trying to commission a compressor that is using a s7-1200 to communicate rs485/modbus to a the compressor interface. My rs485 module is a...
1,704
Is it possible to install Siemens Tia Portal V14 on a machine that already has V16 installed? Or do I need to create a virtual machine to install...
17
8,919
