TIA: String text distributed in IO field
Jeroen Benoot
Oct 2006
Oostkamp [BE]
42
Hello,
I have a problem with the length of a string in an IO field.
I use TIA V13 SP1.
I want to read and write to a textfile and then show this string on a TP700.
I am able to do this with scripts, but when the length of the string exceeds the width of the panel, then the rest remains invisible.
Is there a way to make this IO field distributed, so that all the text is always visible?
Could you cut up your string and distribute it over multiple internal tags in your HMI?
In that case you would have to figure out where your spaces are, as not to cut in the middle of a word.
I thought of that my self, but as you said it requires some code to find the spaces as to not separate the words.
I was just wondering if there was any other way to do this, easily implemented in WinCC.
Does anyone know why my one string is displaying this way? It is causing issues with my HMI displaying it.
273
Hi I have a vision camera that I’m getting the string data P908765 from the vision on an advance trigger .which im using a S -move. Then I put...
382
Hi, I'm looking for a way to find the correct recipe number from a String ID. I have an array [amount defined by constant] of recipe UDT. Each...
2,456
hi all i hope your well i have got 2 plcs a siemens 1500 and 1200 comunicating a data black only 2 values in a wstring i need to get a code...
2,079
Hello all, Can anyone tell me if it is possible to access a tag in TIA Portal by reading the tag name from a string variable? I should add that...
7,988
