TIA v15 WinCC Advanced - embedded trend???
pisoj
Jul 2018
Osijek
Hello to all of you.
As we all know trends are super cool and useful, but kinda ugly in TIA.
I wonder is it possible to make some kind of embedded trend in TIA v15 WinCC Advanced.
It would show nice and clean graph of analog value in certain timespan.
So my goal is to make something like this (if it is possible):
https://imgur.com/a/2iu4zW5
If anyone has idea, or has done something similar, it would be great to share few ideas and insights.
I will post any updates as I am working on it.
Thanks and best regards!!:nodi:
I dunno, I think the trends in TIA look OK. You can tweak a lot of colors and fonts, and enable and disable features.
The tank vessel with a trend and a bar you can make in TIA with a bit of tweaking of the parameters.
I think it is not worth the effort to try and make one by one self.
Also, as of TIA V14 it is no longer possible to connect tags to the external .net controls that you add to WinCC.
First of all, thanks for your reply!
I used the object called Bar to represent a tank, or something similar. It looks pretty good.
The trends...eh. They are another story. I tried to use them, but even after deselecting most of the options, they are still ugly - for example, i cannot make the background transparent to show only graph, i cannot make the blue line that indicates a window go away.
https://imgur.com/a/kLr7nW6
This is the only reason ii would like to know if it is possible to make something similar in my first post - nice and clean "trend" that will show me only few hours worth of data.
For anything more, I will use IBA or dedicated Trend/Historical page with ugly trends :)
Is there any possibility to convert the project in TIA V17 Wincc Professional to TIA V15 Wincc Professional or Wincc Advance?
1,237
I have 2 TIA Wincc projects. One project is in TIA V17 Wincc Professional and other project is in TIA V15 Wincc Advance. How can I copy the Wincc...
1,250
hello all, I have a project in Wincc V15 and I need to copy some screens from V15 to V12 TIA. How do I it. I cant copy paste as there are...
1,924
I am currently am in a PLC class and need urgent help on how the ladder logic would be laid out. I understand how to get the traffic lights to...
19
446
Hi Folks, Looking for support and ideas. We are trying to go online to monitor/fault find on an S7-300 programmed with TIA Portal V15. I can...
353
