Time script
Ones_Zeros
Feb 2014
at work
367
Hey guys,
Working with Wonderware to write a time
Script that I’m using for a calculation.
How is best way to do this?
For example if I write it like this my time
Script doesn’t change.
Script triggering by condition $Minute
If $hour == 22 AND $Minute == 15
Then timescript = 22.25
Else
If $Hour == 22 AND $Minute == 30
Then timescript = 22.50
Else
If $Hour == 22 AND $Minute == 45
Then timescript =22.75
Does this look right? For some reason I can’t get
The values to 22.25,22.50,22.75 to
Populate in my memory real tag.
I appreciate the help!
Try putting parenthesis around your conditions. Without them, your logic would scan like this ((($hour == 22) AND $Minute) == 15).
Also, you probably already know this but the script wont validate if you don't have ";" at the end of the timescripts statements and you need endif's.
Hello Experts I am working on a project with WinCC Unified v16 PC system and want to create an option on the screen to export logs to the...
33
Hello, I am learning to create shapes and VB Scripts in HMIWeb Display Builder. I wanted to change color of my rounded rectangle by script. I...
112
Hello, I have a quick question. I have been using scripts to change the color of buttons. The reason, I am usually using multiple hmiruntime.tags...
105
Hi All, I'm keep getting double quotes in between selections rather than the beginning and the end. Here's the script and please help to find...
802
Dear guys, I am not a programmer but I can do simple things myself. I'm stuck with the following. if I want to extract a value from my rx3i...
46
4,787
