Time Stamp in RSView ME
rta53
Feb 2003
North Carolina
619
I am trying to do a time stamp using a string display in RSView ME. I do this in RSView32 using an event and the system\time tag. What I am doing is time stamping say a pressure every 5 minutes somewhat like the log file would do. Except I would have 3 string displays of time that would be overwritten every 15 minutes with new times. Anyone know of a way to do this?
Randy
I guess I should have mentioned I am using a ML1200 which does not have a RTC. Guess I better get a RTC module in a hurry. Would I be able to copy the time from the function file to a string instruction?
ok, I've been reading some technotes about various ways of getting integer data into string files. I understand that in order to use the hours, minutes, and seconds of the Real Time Clock in the ML1200 you have to copy the Function files to integer files. It seems to me in order to get the h,m,s into one String file I could use 3 AIC instructions and then use 2 ACN instructions. I could then do a MOV instruction anytime I wanted to do a time stamp. :rolleyes:
Does anybody know how 'timestamp output' functionality internally works in a controller? I do not mean the instructions you use as a programmer...
70
Hello Everyone, I hope we are all good! I have a strange one, and wondering if anyone has seen this before. When I look at the CSV Export Logs...
1,618
So I've got an issue I have yet to figure out. I have a PVPlus standard HMI runtime v12. I've gone into the system and set the date and time and...
4,872
Hi.. I was looking for a bit of help from someone that works with intouch scada... At the moment I have a Box that contains an animated Tick when...
2,775
Dear Members; I make a date and time stamp by using GSV and SSV instructions. The DINT array with 7 elements stores those values. Now I want to...
1,516
