Steve Bailey
I think it's 5.610 Lbs
That's not a torque.
3. Does it matter where you grab the torque wrench when you're tightening the nut?
A: NO. If you grab-on at the end (assuming a parallel alignment), you only need to apply the actual required pounds of force; 2.952-Lbs of Force. The indicator will show 2.952 Ft-Lbs of Torque.
However, if you grab-on closer to the head, then you will need to apply more actual pounds of force. The closer to the head, the more actual force is required. However, the indicator will still indicate the "effective torque". You need to apply whatever force is necessary to produce an indication of 2.952 Ft-Lbs of torque. The indication is based on the assumption that the user will grab-on at the handle.
As you grab-on closer to the head you have to apply more force. If you grab-on at the common point (point "B") then you have to apply 3.936-Lbs of Force (3.936-Lbs x .75-Ft = 2.952 Ft-Lbs). However, the indicator will show Zero Ft-Lbs because no force is being applied through the torque wrench.
Steve Bailey said:A torque wrench measures the torque at its pivot point. When the pivot point of the torque wrench is aligned with the point where you really want to measure torque, it doesn't matter where you apply the force.
