Touchscreen scratches/scuffing
JohnRatHolten
Jul 2012
St.Louis
101
Hey All,
I'm wondering if anyone has some good tip/tricks for dealing with scratches and scuffs on touchscreens.
At this point I'm working on a PV+1000, that someone had cleaned with a scotchbrite pad.
Anyone tried using "headlight scratch remover" or something similar?
Regards,
JohnR
Hey All,
Regards,
JohnR
If the "if it's broke you can' make it worse" principle applies, I would try wet-sanding (220-, then 400-, finally 600-grit), then a very thin layer of something like clear varnish or polyurethane with the same refractive index (check in a corner that this does not dissolve the material first, and that it does not affect the touch mechanics/electrics, of course).
That's Wooden Bridge Syndrome though.
https://www.google.com/search?&q=touchscreen+scuff+repair yields toothpaste, alcohol, baking soda and a pencil eraser.
I have 2 PV Plus 7 screens used in the same system that both have touch screens that can be challenging to activate after they haven't been...
577
Hi everyone. I worked with RedLion HMI several years, in the last year four CR3000 HMI (10 and 15") had have problems with the touchscreen. All...
1,274
Every time I power this unit up it loses its IP address and goes to DHCP . When I goto the config the IP address is 0.0.0.0
737
I have a FactoryTalk View ME application that was has been converted to an SE application. I installed it under SE Station version 13 and it...
2,218
Does anyone know how to disable the touchscreen on a panel view 700 plus. Its in a dirty environment and it would be nice to be able to only use...
1,201
