Turck armor block to RSLOGIX tags
Karinrinkashi
Nov 2017
Atlanta, GA
40
Hey everyone
I am working with a TURCK "Armor Block" which we are using with one of our machines. So I added the block to my I/O list in the RSLogix and it created the tags for it. It all seems pretty straight forward but one thing that is really confusing me is the nature of the tags created.
For example: The "Armor Block" has 8 port on it with each port having the capability of taking in two inputs using a splitter. So in all, I have 16 input capability and they are all discrete inputs. But the tags created have an array of input[0] to input[9] for that block which shows as if the block as 10 ports but it only has 8. Secondly, when I collapse any of those input arrays it shows like 8 bits to each of them input[0].0,1,2,3,4,5,6,7 <----- Data
My intuition told me that a block with 8 ports and each port with 2 input capability should create a tag structure like this: Block.input[0] to Block.input[7] (for the 8 ports) and each input should only have 2 discrete data bits like Block.input[0].0,1
Any input would be great!
Thank you
Do you have the exact part number? Usually Turk posts a data map and for their products in a manual. The other bits are probably various status bits.
The part number is 6814012 TBEN-L4-16DXP
And the page number that makes some sense is page 22 in the manual.
I just need to confirm the word and bit offset it is talking about. What do you think it is saying? So, to me, it is saying that whatever the word offset is, that is where the data is going to from the block. And then inside the Data[9] in the example, there are 16 bits and each port has 2 bits for it, that is where the bit offset comes in. If you add the bit offset to the channel input value it skips one bit for each, hence giving each channel two bits
It will make sense when you look at the manual. I just want to know if that is what you also think so.
Karin
See this manual, page 81.
https://www.turck.us/attachment/100000300.pdf#page67
I used about 10 of those modules on a project in 2018. I can confirm the mapping for you with a known project but it won’t be until next week.
In your program, create tags and then alias them to the turck data bits. That way if any are wrong you can easily update them in your program.
I have been Tasked with wiring an i/o link block to an existing machine, and use a few proximity switches and a q4x laser distance sensor to...
426
Hello Experts, I have a Turck Encoder connected to P+F IO Link master communicating over Ethernet/IP with Allen Bradley PLC in Studio 5000 v34...
728
When using Turck BL20 analog and Siemens S7 can someone tell me if the scaling in S7 is still 0-27648 (for 0-10vdc/4-20ma) or is it something...
1,841
Good Morning all, I'm wondering if there are any Banner or Turck reps that hang out on this forum. We are (as I'm sure MANY of you are) having...
1,050
Trying to turn Port 1 (C1) into an output port but I am unable to figure it out. Moving a 0 into the port configuration which is IO link without...
1,477
