Turck FEN20-EN1
jdelgado89
Aug 2008
NC
Hi
I wanted to check if anyone is using the Turck FEN20-EN1 as a NAT it looks like you can actually do up to 5 1 to 1 NAT. I have 10 panels with 2 devices a PLC and a Drive that and I would like to NAT the PLC out so it looks like a very affordable solution.
I haven't used the NAT, but I've used several of the same FEN modules and all have been pretty stellar.
The OS is all stored in the block and you can easily update/change/set all of the blocks I've used with little to no hassle.
The only downside (?) is the FEN series has CONSTANT updates. The platform seems to be pretty aggressively engineered. There are things you can do this month you couldn't do the month before.
I didn't realize there was a network bridge/router version of that FEN20 multiprotocol I/O block.
I am going to read up on it... at least, when I find their English user manual (only the covers were translated !)
That's pretty cool, especially in that tiny form factor.
I have been Tasked with wiring an i/o link block to an existing machine, and use a few proximity switches and a q4x laser distance sensor to...
424
Hello Experts, I have a Turck Encoder connected to P+F IO Link master communicating over Ethernet/IP with Allen Bradley PLC in Studio 5000 v34...
728
When using Turck BL20 analog and Siemens S7 can someone tell me if the scaling in S7 is still 0-27648 (for 0-10vdc/4-20ma) or is it something...
1,840
Good Morning all, I'm wondering if there are any Banner or Turck reps that hang out on this forum. We are (as I'm sure MANY of you are) having...
1,050
Trying to turn Port 1 (C1) into an output port but I am unable to figure it out. Moving a 0 into the port configuration which is IO link without...
1,477
